Zum Hauptinhalt wechseln
How to Repair a Hole in a Shirt
Was du brauchst
  1. How to Repair a Hole in a Shirt, How to Repair a Hole in a Shirt: Schritt 1, Bild 1 von 1
    • Find the hole in the shirt. Spread out the shirt where hole is but don't spread the hole.
  2. How to Repair a Hole in a Shirt: Schritt 2, Bild 1 von 1
    • After you have found the hole put your hand underneath. Get the needle and thread and from underneath the shirt, start putting the needle through the shirt.
  3. How to Repair a Hole in a Shirt: Schritt 3, Bild 1 von 1
    • When you have the needle through you will need to stitch the hole close from the inside by going in out of the fabric.
  4. How to Repair a Hole in a Shirt: Schritt 4, Bild 1 von 1
    • After the hole is closed by stitching it. You will need to go back over the top of the hole called the seem and sew that down flat.
  5. How to Repair a Hole in a Shirt: Schritt 5, Bild 1 von 2 How to Repair a Hole in a Shirt: Schritt 5, Bild 2 von 2
    • After the seem is sewn down you do a topstitch which is just a tighter neater regular stitch. After you get the end you will need to to tie a knot and cut the thread.
  6. How to Repair a Hole in a Shirt: Schritt 6, Bild 1 von 1
    • Here what it is supposed to look like and it is best if you wash the shirt but it doesn't not hurt if you don't.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 56
Insgesamt: 919
