Zum Hauptinhalt wechseln
How to Repair a Hole in an Inflatable Floatie
Was du brauchst
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: Schritt 1, Bild 1 von 3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: Schritt 1, Bild 2 von 3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: Schritt 1, Bild 3 von 3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: Schritt 2, Bild 1 von 2 How to Repair a Hole in an Inflatable Floatie: Schritt 2, Bild 2 von 2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: Schritt 3, Bild 1 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 3, Bild 2 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 3, Bild 3 von 3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: Schritt 4, Bild 1 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 4, Bild 2 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 4, Bild 3 von 3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: Schritt 5, Bild 1 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 5, Bild 2 von 3 How to Repair a Hole in an Inflatable Floatie: Schritt 5, Bild 3 von 3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: Schritt 6, Bild 1 von 2 How to Repair a Hole in an Inflatable Floatie: Schritt 6, Bild 2 von 2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
Abschluss
Enjoy your renewed floatie!
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 33
Letzte 30 Tage: 76
Insgesamt: 253
