Zum Hauptinhalt wechseln
How to Repair a Loose Impress Mighty Mite Fan
Was du brauchst
  1. How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: Schritt 1, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: Schritt 1, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan, How to Repair a Loose Impress Mighty Mite Fan: Schritt 1, Bild 3 von 3
    • Remove the single 0.8 mm screw using a Phillips #2 screwdriver. Use a pair of pliers to hold the hexagon nut so that it makes the process easier.
  2. How to Repair a Loose Impress Mighty Mite Fan: Schritt 2, Bild 1 von 2 How to Repair a Loose Impress Mighty Mite Fan: Schritt 2, Bild 2 von 2
    • Disconnect the hinges that hold the fan covers together.
  3. How to Repair a Loose Impress Mighty Mite Fan: Schritt 3, Bild 1 von 2 How to Repair a Loose Impress Mighty Mite Fan: Schritt 3, Bild 2 von 2
    • Remove the front cover and set it aside.
  4. How to Repair a Loose Impress Mighty Mite Fan: Schritt 4, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 4, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 4, Bild 3 von 3
    • Use the Phillips #2 screwdriver to remove the 1.4 mm screw that holds the fan blades to the fan.
  5. How to Repair a Loose Impress Mighty Mite Fan: Schritt 5, Bild 1 von 2 How to Repair a Loose Impress Mighty Mite Fan: Schritt 5, Bild 2 von 2
    • Remove the fan blades and set them aside.
  6. How to Repair a Loose Impress Mighty Mite Fan: Schritt 6, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 6, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 6, Bild 3 von 3
    • Position the fans back cover correctly aligned with its placeholders.
    • The placeholders are small and black which are not too visible on camera. There are two placeholders and they are shaped like cylinders.
  7. How to Repair a Loose Impress Mighty Mite Fan: Schritt 7, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 7, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 7, Bild 3 von 3
    • Twist the big knob clockwise, that holds the back cover, until it is tight and you can no longer twist.
    • The back cover must be correctly placed on its holders before this step.
  8. How to Repair a Loose Impress Mighty Mite Fan: Schritt 8, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 8, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 8, Bild 3 von 3
    • Place the fan blades back onto the fan and start screwing the 1.4 mm cross head screw into the clockwise direction until it is flat and can no longer screw.
  9. How to Repair a Loose Impress Mighty Mite Fan: Schritt 9, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 9, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 9, Bild 3 von 3
    • Place the front cover back onto the fan with the punch-holes aligned so that the small bolt can go through.
    • These punch-holes should be aligned and you should be able to see through it.
  10. How to Repair a Loose Impress Mighty Mite Fan: Schritt 10, Bild 1 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 10, Bild 2 von 3 How to Repair a Loose Impress Mighty Mite Fan: Schritt 10, Bild 3 von 3
    • Place the .8 mm cross head screw back inside the punch-hole and start screwing the hexagon nut by hand so that this process is easier.
    • Do not tighten this too much as you might need to repeat the whole process in the future of your fans usage.
  11. How to Repair a Loose Impress Mighty Mite Fan: Schritt 11, Bild 1 von 2 How to Repair a Loose Impress Mighty Mite Fan: Schritt 11, Bild 2 von 2
    • Close the hinges so that the covers are joined back together.
Abschluss
To repeat the process start from step 1.
Alexis S
193 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 11-20, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-20, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G20
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 772
