Zum Hauptinhalt wechseln
How to Repair a Loose Modern Gooseneck Water Faucet
Was du brauchst
  1. How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 1, Bild 1 von 3 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 1, Bild 2 von 3 How to Repair a Loose Modern Gooseneck Water Faucet, How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 1, Bild 3 von 3
    • On the bottom of the sink, you will see a water tank.
    • The next step is to close the vault. Slowly turn the vault to the right side.
    • You can see the vault is 90 degrees opposite to the direction when it was opened. That means it is now closed.
  2. How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 2, Bild 1 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 2, Bild 2 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 2, Bild 3 von 3
    • Check again by opening the tap to see if water is coming out of it or not.
    • Due to the loose neck, water is leaking from the sink.
    • The leakage can cause damage in the future, so, it is necessary to tighten the loose neck of the water dispenser.
  3. How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 3, Bild 1 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 3, Bild 2 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 3, Bild 3 von 3
    • Readjust the pipe to the way it was originally.
    • Make sure the realignment is properly done and that there are no gaps in it.
    • After, check the realignment from all sides so there are no places from where it can leak.
  4. How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 4, Bild 1 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 4, Bild 2 von 3 How to Repair a Loose Modern Gooseneck Water Faucet: Schritt 4, Bild 3 von 3
    • Use a wrench to adjust and tighten the screw on the right side to secure it in place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 99-99, Harris Spring 2024 Mitglied von CSU Los Angeles, Team 99-99, Harris Spring 2024
CSULA-HARRIS-S24S99G99
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 41
Insgesamt: 502
