Zum Hauptinhalt wechseln
How to Repair a Loose Rear Bicycle Wheel
Was du brauchst
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: Schritt 1, Bild 1 von 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: Schritt 1, Bild 2 von 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: Schritt 1, Bild 3 von 3
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: Schritt 2, Bild 1 von 2 How to Repair a Loose Rear Bicycle Wheel: Schritt 2, Bild 2 von 2
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: Schritt 3, Bild 1 von 2 How to Repair a Loose Rear Bicycle Wheel: Schritt 3, Bild 2 von 2
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: Schritt 4, Bild 1 von 2 How to Repair a Loose Rear Bicycle Wheel: Schritt 4, Bild 2 von 2
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: Schritt 5, Bild 1 von 2 How to Repair a Loose Rear Bicycle Wheel: Schritt 5, Bild 2 von 2
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: Schritt 6, Bild 1 von 3 How to Repair a Loose Rear Bicycle Wheel: Schritt 6, Bild 2 von 3 How to Repair a Loose Rear Bicycle Wheel: Schritt 6, Bild 3 von 3
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: Schritt 7, Bild 1 von 3 How to Repair a Loose Rear Bicycle Wheel: Schritt 7, Bild 2 von 3 How to Repair a Loose Rear Bicycle Wheel: Schritt 7, Bild 3 von 3
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Abschluss
Lily Suggs
145 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-8, Andersen Winter 2023 Mitglied von UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
3 Mitglieder
Ein Kommentar
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 31
Insgesamt: 1,028
