Zum Hauptinhalt wechseln
How to Repair a Loose Screw on a Secretary Desk
Was du brauchst
    1. How to Repair a Loose Screw on a Secretary Desk, How to Repair a Loose Screw on a Secretary Desk: Schritt 1, Bild 1 von 1
      • Place a support (such as boxes or books) beneath the desk to hold it up since you will remove one of the support arms.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Repair a Loose Screw on a Secretary Desk: Schritt 2, Bild 1 von 1
      • Remove the loose screw by hand if it's loose enough. If not, you can use a flathead screwdriver.
      Frag FixBot
    3. How to Repair a Loose Screw on a Secretary Desk: Schritt 3, Bild 1 von 3 How to Repair a Loose Screw on a Secretary Desk: Schritt 3, Bild 2 von 3 How to Repair a Loose Screw on a Secretary Desk: Schritt 3, Bild 3 von 3
      • Use the wooden stick that comes with the JB Weld to mix the two-part epoxy in equal amounts on a disposable plate.
      • Be sure to use epoxy in a well-ventilated space and wear gloves.
      Frag FixBot
    4. How to Repair a Loose Screw on a Secretary Desk: Schritt 4, Bild 1 von 2 How to Repair a Loose Screw on a Secretary Desk: Schritt 4, Bild 2 von 2
      • Use the wooden stick to put the epoxy in the screw hole. JB WoodWeld sets in 15 minutes and cures in 30 minutes. Wait until it's not tacky.
      • It may take more than 30 minutes to fully cure, depending on the environment.
      Frag FixBot
    5. How to Repair a Loose Screw on a Secretary Desk: Schritt 5, Bild 1 von 2 How to Repair a Loose Screw on a Secretary Desk: Schritt 5, Bild 2 von 2
      • Sand with a sanding block until the epoxy is flush with the wood.
      • You can use an electric sander for this step, but it is not required.
      Frag FixBot
    6. How to Repair a Loose Screw on a Secretary Desk: Schritt 6, Bild 1 von 1
      • Mark the drill bit with tape. Use the screw to measure where to place the tape so you don't drill the hole too deep.
      Frag FixBot
    7. How to Repair a Loose Screw on a Secretary Desk: Schritt 7, Bild 1 von 1
      • Drill the pilot hole, stopping once the tape reaches the wood to ensure you don't drill too deep
      • This guide uses a 1/8-inch drill bit.
      Frag FixBot
    8. How to Repair a Loose Screw on a Secretary Desk: Schritt 8, Bild 1 von 3 How to Repair a Loose Screw on a Secretary Desk: Schritt 8, Bild 2 von 3 How to Repair a Loose Screw on a Secretary Desk: Schritt 8, Bild 3 von 3
      • Place the opening lever over the hole. Use a flathead screwdriver to screw it into place. Do not screw in past the threading on the screw; you need some of the screw sticking out to hold the arm in place.
      Frag FixBot
Ziellinie
Kaitlyn French
157 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-8, Bray Spring 2026 Mitglied von Austin Community College, Team 1-8, Bray Spring 2026
AUSTINCC-BRAY-S26S1G8
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 63
