Zum Hauptinhalt wechseln
How to Repair a Painting Frame
Was du brauchst
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: Schritt 1, Bild 1 von 3 How to Repair a Painting Frame, How to Repair a Painting Frame: Schritt 1, Bild 2 von 3 How to Repair a Painting Frame, How to Repair a Painting Frame: Schritt 1, Bild 3 von 3
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: Schritt 2, Bild 1 von 1
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: Schritt 3, Bild 1 von 1
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: Schritt 4, Bild 1 von 3 How to Repair a Painting Frame: Schritt 4, Bild 2 von 3 How to Repair a Painting Frame: Schritt 4, Bild 3 von 3
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: Schritt 5, Bild 1 von 3 How to Repair a Painting Frame: Schritt 5, Bild 2 von 3 How to Repair a Painting Frame: Schritt 5, Bild 3 von 3
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: Schritt 6, Bild 1 von 1
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: Schritt 7, Bild 1 von 2 How to Repair a Painting Frame: Schritt 7, Bild 2 von 2
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: Schritt 8, Bild 1 von 1
    • After that, you will have a restored painting frame.
Ziellinie
Sofia Morales
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 399
