Zum Hauptinhalt wechseln
How to Repair a Patio Solar Light
Was du brauchst
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: Schritt 1, Bild 1 von 1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: Schritt 2, Bild 1 von 1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: Schritt 3, Bild 1 von 1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: Schritt 4, Bild 1 von 1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: Schritt 5, Bild 1 von 3 How to Repair a Patio Solar Light: Schritt 5, Bild 2 von 3 How to Repair a Patio Solar Light: Schritt 5, Bild 3 von 3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: Schritt 6, Bild 1 von 1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Abschluss
Miguel Antonio Gonzales
133 Reputation
1 Anleitung geschrieben
University of Arizona, Team 2-7, Cools Stephens Spring 2024 Mitglied von University of Arizona, Team 2-7, Cools Stephens Spring 2024
ARIZONA-COOLS STEPHENS-S24S2G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 61
