Zum Hauptinhalt wechseln
How to Repair a Rip in a Cashmere Scarf
Was du brauchst
  1. How to Repair a Rip in a Cashmere Scarf, How to Repair a Rip in a Cashmere Scarf: Schritt 1, Bild 1 von 2 How to Repair a Rip in a Cashmere Scarf, How to Repair a Rip in a Cashmere Scarf: Schritt 1, Bild 2 von 2
    • Lay your cashmere scarf on a flat and clean surface.
  2. How to Repair a Rip in a Cashmere Scarf: Schritt 2, Bild 1 von 1
    • Trim any stray/loose threads off the ripped area.
  3. How to Repair a Rip in a Cashmere Scarf: Schritt 3, Bild 1 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 3, Bild 2 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 3, Bild 3 von 3
    • Thread your needle through the hole at the bottom and tie a knot at one end.
  4. How to Repair a Rip in a Cashmere Scarf: Schritt 4, Bild 1 von 2 How to Repair a Rip in a Cashmere Scarf: Schritt 4, Bild 2 von 2
    • Start your needle at the bottom of the rip to secure the end knot through a first small stitch.
  5. How to Repair a Rip in a Cashmere Scarf: Schritt 5, Bild 1 von 1
    • Insert your needle across your first stitch and then do a vertical stitch.
  6. How to Repair a Rip in a Cashmere Scarf: Schritt 6, Bild 1 von 1
    • Repeat this action until you have almost reached the top of the rip.
  7. How to Repair a Rip in a Cashmere Scarf: Schritt 7, Bild 1 von 1
    • Gradually make the top stitches closer together.
  8. How to Repair a Rip in a Cashmere Scarf: Schritt 8, Bild 1 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 8, Bild 2 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 8, Bild 3 von 3
    • Pull the string to close up the rip.
  9. How to Repair a Rip in a Cashmere Scarf: Schritt 9, Bild 1 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 9, Bild 2 von 3 How to Repair a Rip in a Cashmere Scarf: Schritt 9, Bild 3 von 3
    • Secure your sewing with a knot at the back.
    • Cut off the excess sewing thread.
Abschluss
You've completed the repair! To undo your sewing, just cut the thread and pull it out.
2 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team 2-6, Vidal-Chiesa Fall 2024 Mitglied von UC Davis, Team 2-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G6
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 52
Insgesamt: 754
