Zum Hauptinhalt wechseln
How to Repair a Scratched CD
Was du brauchst
  1. How to Repair a Scratched CD, How to Repair a Scratched CD: Schritt 1, Bild 1 von 1
    • Rinse the disc with water and wipe clean to remove any dust or dirt.
  2. How to Repair a Scratched CD: Schritt 2, Bild 1 von 3 How to Repair a Scratched CD: Schritt 2, Bild 2 von 3 How to Repair a Scratched CD: Schritt 2, Bild 3 von 3
    • Apply a rubbing compound, moving from the center of the disc outwards.
    • Use enough force to create a mirror polished surface when rubbing compound application is complete.
    • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
  3. How to Repair a Scratched CD: Schritt 3, Bild 1 von 1
    • Let the CD sit for 5 minutes.
  4. How to Repair a Scratched CD: Schritt 4, Bild 1 von 2 How to Repair a Scratched CD: Schritt 4, Bild 2 von 2
    • Wipe the CD clean with a new rag, removing any excess compound.
  5. How to Repair a Scratched CD: Schritt 5, Bild 1 von 3 How to Repair a Scratched CD: Schritt 5, Bild 2 von 3 How to Repair a Scratched CD: Schritt 5, Bild 3 von 3
    • Apply a thin coat of car wax directly to the CD, using a circular application method.
    • Apply in either small circular motions or large motions that follow the circumference of the disc.
  6. How to Repair a Scratched CD: Schritt 6, Bild 1 von 2 How to Repair a Scratched CD: Schritt 6, Bild 2 von 2
    • Wipe the CD clean, removing any excess wax.
Abschluss
Congratulations! You have successfully repaired the scratched CD!
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Emma Larson
283 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 47
Letzten 30 Tage: 198
Insgesamt: 10,860
