Zum Hauptinhalt wechseln
How to Repair a Silent Wall Clock Mechanism
Was du brauchst
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: Schritt 1, Bild 1 von 1
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: Schritt 2, Bild 1 von 1
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: Schritt 3, Bild 1 von 1
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: Schritt 4, Bild 1 von 1
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: Schritt 5, Bild 1 von 1
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: Schritt 6, Bild 1 von 1
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: Schritt 7, Bild 1 von 1
    • Put the faceplate back on and assemble all of the pieces of the clock.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team 1-15, O'Regan Winter 2022 Mitglied von York University, Team 1-15, O'Regan Winter 2022
YORK-O'REGAN-W22S1G15
1 Mitglied
2 Anleitungen geschrieben
2 Kommentare
catellano por favor.gracias.
mario oscar Fiori - Antwort
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 42
Letzte 30 Tage: 194
Insgesamt: 5,313
