Zum Hauptinhalt wechseln
How to Repair a Small Hole in Your Clothing
Was du brauchst
  1. How to Repair a Small Hole in Your Clothing, How to Repair a Small Hole in Your Clothing: Schritt 1, Bild 1 von 1
    • Grab the clothing you want to fix and lay it on a table.
  2. How to Repair a Small Hole in Your Clothing: Schritt 2, Bild 1 von 1
    • Find the thread that matches the colour of the clothing you are going to repair.
    • Measure and cut a piece of string a minimum of 20x the length of the hole.
  3. How to Repair a Small Hole in Your Clothing: Schritt 3, Bild 1 von 3 How to Repair a Small Hole in Your Clothing: Schritt 3, Bild 2 von 3 How to Repair a Small Hole in Your Clothing: Schritt 3, Bild 3 von 3
    • Insert the thread through the eye of the needle.
  4. How to Repair a Small Hole in Your Clothing: Schritt 4, Bild 1 von 3 How to Repair a Small Hole in Your Clothing: Schritt 4, Bild 2 von 3 How to Repair a Small Hole in Your Clothing: Schritt 4, Bild 3 von 3
    • Pull the thread through until the length of both ends of the thread are the same length.
    • Tie the ends in a double knot.
  5. How to Repair a Small Hole in Your Clothing: Schritt 5, Bild 1 von 3 How to Repair a Small Hole in Your Clothing: Schritt 5, Bild 2 von 3 How to Repair a Small Hole in Your Clothing: Schritt 5, Bild 3 von 3
    • Pinch the fabric to close the hole, and weave the needle back and forth through the pinch until the hole is sealed.
  6. How to Repair a Small Hole in Your Clothing: Schritt 6, Bild 1 von 2 How to Repair a Small Hole in Your Clothing: Schritt 6, Bild 2 von 2
    • Cut the thread from the needle and cut the leftover thread on both ends of the sealed hole.
  7. How to Repair a Small Hole in Your Clothing: Schritt 7, Bild 1 von 1
    • The hole is completely sealed!
Ziellinie
Ann
145 Reputation
1 Anleitung geschrieben
York University, Team S3-G66, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G66, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G66
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 40
Letzte 30 Tage: 207
Insgesamt: 4,832
