Einleitung
This instruction manual will teach you how to fix a loose input jack for a Squier Affinity Series Stratocaster by Fender.
After the first few times playing a new guitar, you may notice that your input jack is loose. Your audio cables may not be fitting in properly as it’s too loose, or is creating little sound output.
As a first time guitar owner, it may seem challenging to fix parts of your Stratocaster at home. However there is no need to worry, as this guide will walk you through everything so you can get back to jamming in a matter of minutes.
Was du brauchst
Using the Phillips #3 screwdriver, remove the two 1.2 mm screws that are connected to the plate.
Test the tightness of your input jack before plugging your audio cable into your amplifier.
Plug the guitar into the amplifier to test the audio cable sensitivity and output quality.
That is all you need to do to fix your Squier Affinity Stratocaster’s input jack. Now have fun making music!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
