Zum Hauptinhalt wechseln
How to Repair a Stuck Trailer Jack
Was du brauchst
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: Schritt 1, Bild 1 von 1
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
  2. How to Repair a Stuck Trailer Jack: Schritt 2, Bild 1 von 1
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
  3. How to Repair a Stuck Trailer Jack: Schritt 3, Bild 1 von 1
    • Lift the spacer or washer upward.
    • Set the washer aside.
  4. How to Repair a Stuck Trailer Jack: Schritt 4, Bild 1 von 1
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
  5. How to Repair a Stuck Trailer Jack: Schritt 5, Bild 1 von 1
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
  6. How to Repair a Stuck Trailer Jack: Schritt 6, Bild 1 von 1
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
  7. How to Repair a Stuck Trailer Jack: Schritt 7, Bild 1 von 1
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
  8. How to Repair a Stuck Trailer Jack: Schritt 8, Bild 1 von 1
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
  9. How to Repair a Stuck Trailer Jack: Schritt 9, Bild 1 von 1
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
  10. How to Repair a Stuck Trailer Jack: Schritt 10, Bild 1 von 1
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
  11. How to Repair a Stuck Trailer Jack: Schritt 11, Bild 1 von 1
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
  12. How to Repair a Stuck Trailer Jack: Schritt 12, Bild 1 von 1
    • Install the jack to the trailer and test for correct operation.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - Antwort
What if the trailer jack is frozen in the position. And the gears on top are well greased?
Wesley Ramsey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 112
Letzte 30 Tage: 534
Insgesamt: 20,793
