Zum Hauptinhalt wechseln
How to Repair a Stuck or Broken Chainsaw Rope
Was du brauchst
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: Schritt 1, Bild 1 von 2 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: Schritt 1, Bild 2 von 2
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 2, Bild 1 von 1
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 3, Bild 1 von 2 How to Repair a Stuck or Broken Chainsaw Rope: Schritt 3, Bild 2 von 2
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 4, Bild 1 von 2 How to Repair a Stuck or Broken Chainsaw Rope: Schritt 4, Bild 2 von 2
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 5, Bild 1 von 1
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 6, Bild 1 von 1
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 7, Bild 1 von 1
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 8, Bild 1 von 1
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 9, Bild 1 von 2 How to Repair a Stuck or Broken Chainsaw Rope: Schritt 9, Bild 2 von 2
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 10, Bild 1 von 1
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 11, Bild 1 von 2 How to Repair a Stuck or Broken Chainsaw Rope: Schritt 11, Bild 2 von 2
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 12, Bild 1 von 1
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 13, Bild 1 von 1
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: Schritt 14, Bild 1 von 1
    • Pull on the rope to make sure the chainsaw works.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 401
