Einleitung
A good pair of leather boots can be used for whatever and whenever. Be it for style or for work, these boots are meant to last. But like everything else, they'll get worn and broken down. Eventually they won't be the same they once were.
In the case that you've torn your leather boots, this guide is perfect for you. Leather is a hard material to work with. But with our guide, we made it so that you could breath new life into your favorite leather boots using only household or easy to acquire materials.
With just seven steps, your torn leather boots can look and function like brand new!
Was du brauchst
Prepare your leather boot with the listed materials:
Using alcohol wipes or any leather cleansing products, clean targeted and surrounding area to rid debris.
Fill the boot with a paper towel, rag, or piece of cloth.
Filling is sufficient when the tear protrudes slightly.
Set a 10 minute timer to allow for the glue to dry. Make sure that the shoes are dried before proceeding on to the next step.
After the Shoe Goo has fully dried make sure to clean up any excess Goo from the shoe that is unnecessary for the repair.
Remove any of the towels, or rags that were originally inserted within the shoes.
After completing all the listed steps above your shoes should be repaired and ready to go. By applying Shoe Goo to your product you have restored the life of your item once again. This procedure is very simple and can be completed several times on the same item.
Ein Kommentar
Why shoe goo? The end result is a clear semi-clear goo appearance that cant be dyed or colored.
