Zum Hauptinhalt wechseln
How to Repair a Trophy
Was du brauchst
  1. How to Repair a Trophy, How to Repair a Trophy: Schritt 1, Bild 1 von 3 How to Repair a Trophy, How to Repair a Trophy: Schritt 1, Bild 2 von 3 How to Repair a Trophy, How to Repair a Trophy: Schritt 1, Bild 3 von 3
    • Put the cylindrical tube on the small threaded rod of the cup.
    • Turn to the right until you tighten it completely.
  2. How to Repair a Trophy: Schritt 2, Bild 1 von 3 How to Repair a Trophy: Schritt 2, Bild 2 von 3 How to Repair a Trophy: Schritt 2, Bild 3 von 3
    • Place the longest threaded rod on the opposite side of the cylindrical tube and twist again to the right until it is tight.
  3. How to Repair a Trophy: Schritt 3, Bild 1 von 3 How to Repair a Trophy: Schritt 3, Bild 2 von 3 How to Repair a Trophy: Schritt 3, Bild 3 von 3
    • Put all the pieces on in the correct order.
    • If you put them on in the wrong order they won't fit.
  4. How to Repair a Trophy: Schritt 4, Bild 1 von 3 How to Repair a Trophy: Schritt 4, Bild 2 von 3 How to Repair a Trophy: Schritt 4, Bild 3 von 3
    • Insert the nut into the hub of the 3/8 drive ratchet wrench.
    • Use the 3/8 inch ratchet wrench to secure the nut at the bottom of the trophy. Turn the nut clockwise until it is fully secure.
  5. How to Repair a Trophy: Schritt 5, Bild 1 von 3 How to Repair a Trophy: Schritt 5, Bild 2 von 3 How to Repair a Trophy: Schritt 5, Bild 3 von 3
    • Glue the remaining two pieces to the side of the trophy.
    • Allow them to dry before touching to prevent them from coming off.
  6. How to Repair a Trophy: Schritt 6, Bild 1 von 1
    • Wait some time (approximately 30 minutes) until the pieces have dried completely.
    • And your done!!
Abschluss
This work will be completed when all the pieces are tight and without coming off. Remember not to touch the glued pieces too much to avoid breaking them again. I hope you had fun arranging a good memory.
Yazly Bonilla
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 88
Insgesamt: 1,588
