Zum Hauptinhalt wechseln
How to Repair a Vileda Turbo Mop Bucket Set
Was du brauchst
  1. How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: Schritt 1, Bild 1 von 2 How to Repair a Vileda Turbo Mop Bucket Set, How to Repair a Vileda Turbo Mop Bucket Set: Schritt 1, Bild 2 von 2
    • No Parts Required
  2. How to Repair a Vileda Turbo Mop Bucket Set: Schritt 2, Bild 1 von 1
    • Run the few drops of oil down the chrome shaft
Abschluss
Get back to work !
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Paul
768 Reputation
4 Anleitungen geschrieben
8 Kommentare
I had the same problem but fixed it slightly different. I turned the empty bucket upside down, removed the four pz2 screws. Lifted out gearing in one piece. Removed rust/debris from two month old bucket stainless steel shaft and sprayed with water dispersant liquid. Reassembled. May sound complicated but very easy and thorough job. Only about 10 minutes, screwdriver and lubricant spray.
jimdeane77 - Antwort
Hi Jim Thanks for your idea. Next time I will go a bit deeper into it. My bucket was already full and ready to go. The few drops of oil got it going straight away.
Paul - Antwort
Sometimes there is too much rust into the gearing.
I replace it with “Octagonal One Way Needle Roller Bearing HF081412 8*14*12mm Fit for EasyMop” found on EBAY (10=$8.90 !)
Like a new ! I takes 10’ !
geek5537 - Antwort
Thanks for the heads up , geek5537. Will take note of the part number. Stay safe.
Paul - Antwort
Where I can buy new pedal? Mine is broken.
Emil Hakobian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 116
Letzte 30 Tage: 520
Insgesamt: 22,555
