Einleitung
For our project, we would like to document the fix of a whiteboard frame left outside and damaged by weather elements. Over time, leaving the whiteboard out has resulted in its inevitable falling apart at its corner joints and paint damage. We will show people how to fix a whiteboard damaged in this way to its original state.
We believe this guide is needed because whiteboard frames tend to be very fragile and can break easily and disconnect from the whiteboard itself. Whiteboards are used a lot in classrooms, workplaces, at home, and within communities, so we believe a tutorial on how to repair them would be helpful. This whiteboard, in particular, has been important to community outreach so it will help bring people together when it is fixed. This guide can also help towards sustainability by giving readers a way to repair a still-functioning whiteboard and not just go out and buy a new one.
Was du brauchst
Gather all your tools which are listed in the tool area.
Start by applying Goo Gone onto a paper towel to remove any sticky residue from the outside of the whiteboard.
Clean the surface using a multipurpose cleaner safe for wood to remove any remaining residue and debris
Apply an even amount of glue to each piece, then place them into position and wipe off any excess glue
Secure the pieces with clamps at the corners and wait for 24 hours to let the glue dry.
After 24 hours, remove the clamps and sand down any rough corners if necessary.
