Zum Hauptinhalt wechseln
How to Repair an Elastic Loop on a Blouse
Was du brauchst
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: Schritt 1, Bild 1 von 1
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: Schritt 2, Bild 1 von 1
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: Schritt 3, Bild 1 von 2 How to Repair an Elastic Loop on a Blouse: Schritt 3, Bild 2 von 2
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: Schritt 4, Bild 1 von 1
    • Simply cut the thread connected to the needle, and then any dangling threads.
Abschluss
Enjoy your revitalized garment!
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 66
Insgesamt: 4,469
