Zum Hauptinhalt wechseln
How to Repair an Unstable Sliding Door
Was du brauchst
  1. How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: Schritt 1, Bild 1 von 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: Schritt 1, Bild 2 von 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: Schritt 1, Bild 3 von 3
    • Investigate the cause of the unstable sliding door.
    • In this case you can see the sliding tract isn't aligned with the bottom roller.
    • You can also see that the screw at the base has been dislodged.
  2. How to Repair an Unstable Sliding Door: Schritt 2, Bild 1 von 3 How to Repair an Unstable Sliding Door: Schritt 2, Bild 2 von 3 How to Repair an Unstable Sliding Door: Schritt 2, Bild 3 von 3
    • Remove the screws used to hold the door in place with a Phillips screwdriver.
    • Once the doors are loose from the tracks, remove them.
  3. How to Repair an Unstable Sliding Door: Schritt 3, Bild 1 von 3 How to Repair an Unstable Sliding Door: Schritt 3, Bild 2 von 3 How to Repair an Unstable Sliding Door: Schritt 3, Bild 3 von 3
    • Check to see that the rollers are securely in place.
    • If there are any bits of debris present on the rollers or the tracks, clean it off with isopropyl alcohol and a clean rag.
  4. How to Repair an Unstable Sliding Door: Schritt 4, Bild 1 von 3 How to Repair an Unstable Sliding Door: Schritt 4, Bild 2 von 3 How to Repair an Unstable Sliding Door: Schritt 4, Bild 3 von 3
    • Place the doors back on the rollers.
    • Replace the screws you removed earlier.
    • Check that the rollers move freely. You can test this by using your hands to roll them forward to your satisfaction.
  5. How to Repair an Unstable Sliding Door: Schritt 5, Bild 1 von 3 How to Repair an Unstable Sliding Door: Schritt 5, Bild 2 von 3 How to Repair an Unstable Sliding Door: Schritt 5, Bild 3 von 3
    • Align the door on both tracks.
    • Start by attaching the head of the door first and then lower body into the track. Avoid forcing into the track as this might damage the rollers.
    • Make sure that it is aligned properly so it does not fall out in the future.
Ziellinie
Barabonye Longjohn
121 Reputation
1 Anleitung geschrieben
York University, Team S1-G30, Woodhouse Fall 2020 Mitglied von York University, Team S1-G30, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G30
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 324
