Zum Hauptinhalt wechseln
How to Repair the Buttons on a Logitech Pebble Mouse
Was du brauchst
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 1, Bild 1 von 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 1, Bild 2 von 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 1, Bild 3 von 3
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 2, Bild 1 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 2, Bild 2 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 2, Bild 3 von 3
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 3, Bild 1 von 2 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 3, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 4, Bild 1 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 4, Bild 2 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 4, Bild 3 von 3
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 5, Bild 1 von 1
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 6, Bild 1 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 6, Bild 2 von 3 How to Repair the Buttons on a Logitech Pebble Mouse: Schritt 6, Bild 3 von 3
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UC Davis, Team 2-6, Morris Spring 2023 Mitglied von UC Davis, Team 2-6, Morris Spring 2023
UCD-MORRIS-S23S2G6
3 Mitglieder
1 Anleitung geschrieben
2 Kommentare
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Antwort
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 23
Letzte 30 Tage: 134
Insgesamt: 1,790
