Zum Hauptinhalt wechseln
How to Repair the Jump Ring on a Mask Holder
Was du brauchst
  1. How to Repair the Jump Ring on a Mask Holder, How to Repair the Jump Ring on a Mask Holder: Schritt 1, Bild 1 von 1
    • Remove the broken or opened jump ring from your mask holder.
  2. How to Repair the Jump Ring on a Mask Holder: Schritt 2, Bild 1 von 1
    • Hold needle nose pliers with one hand and the jump ring in the other.
    • Make sure you have good light so you can see clearly.
  3. How to Repair the Jump Ring on a Mask Holder: Schritt 3, Bild 1 von 2 How to Repair the Jump Ring on a Mask Holder: Schritt 3, Bild 2 von 2
    • Use the pliers to open the jump ring carefully.
  4. How to Repair the Jump Ring on a Mask Holder: Schritt 4, Bild 1 von 1
    • Reattach the chain to the jump ring.
  5. How to Repair the Jump Ring on a Mask Holder: Schritt 5, Bild 1 von 1
    • Use the pliers to close the jump ring.
  6. How to Repair the Jump Ring on a Mask Holder: Schritt 6, Bild 1 von 2 How to Repair the Jump Ring on a Mask Holder: Schritt 6, Bild 2 von 2
    • Make sure the ring is closed tightly so the mask holder stays secure.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 308
