Zum Hauptinhalt wechseln
Einleitung
Is your torch full of butane but not lighting? Your sparker is probably misaligned from your butane tube. Use this guide to see how to fix it!
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch. Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch. Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. Open up the torch. Set aside the empty side of the torch.
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. Pull the handle down as if you were to use the torch. You will see one of the parts inside spark. This is the sparker. Now gently remove the handle and set it aside.
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter. Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. Gently bend the sparker until it is positioned near the opening of the Merlion's mouth. Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. Grab the tube and gently bend it so it faces the opening of the Merlion's mouth. Put the handle back on the torch. Put the handle back on the torch.
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. Take the empty half of the torch and place it over the other half. Take the empty half of the torch and place it over the other half. Take the empty half of the torch and place it over the other half.
    • Take the empty half of the torch and place it over the other half.
  8. Use the screwdriver to put the screws back in the torch. Use the screwdriver to put the screws back in the torch. Use the screwdriver to put the screws back in the torch.
    • Use the screwdriver to put the screws back in the torch.
  9. Hold the torch upside down and position the butane above the torch's hole. Gently press down for five seconds.
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Abschluss
Congrats! Now you can use your Merlion torch again.
2 weitere Nutzer haben diese Anleitung absolviert.
Neel Kogali
173 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-3, Green Fall 2015 Mitglied von Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 11
Letzten 30 Tage: 31
Insgesamt: 5,827
