Einleitung
Cabin air filters are crucial for clearing the cabin of bacteria and dust, eliminating odors, and ensuring adequate airflow for defogging.
Over time, the cabin air filter becomes clogged from dirt and debris. It may be time to replace the filter if your car is smelling musty, or your heating/cooling is ineffective. If you do not replace your cabin air filter, you may begin to breathe in harmful pollutants like pollen and dust while driving, which can be especially harmful to people who suffer from asthma or allergies. It will also be difficult to defog your windshield, reducing your visibility.
Toyota recommends replacing your cabin air filter every 15,000 miles, and they charge a premium to do it. Use this guide to replace the cabin air filter in your 2002-2006 Toyota Camry yourself, saving you time and money. Replacement cabin air filters can be purchased at your local auto parts store.
Was du brauchst
Open the glove box in the passenger seat of your car, and empty anything inside.
Use a Phillips #2 screwdriver to remove the single 16.2 mm screw retaining the rod hook on the right side of the glove box.
Press inward on both sides of the glove box to release the stops.
Remove the glove box and set it aside.
Push on the bottom of the air filter to loosen it from the plastic frame.
Flip the filter over and push the side of it until it releases from the frame.
Slide the folds of the new filter towards one end of the frame so that the entire filter fits within the plastic tightly.
Push inward on both sides of the glove box.
Raise the glove box until it holds in the housing without support.
Pull down the rod on the right side of the glovebox and push the hook back around the hinge.
Enjoy the fresh air!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
