Zum Hauptinhalt wechseln
How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers
Was du brauchst
  1. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: Schritt 1, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: Schritt 1, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: Schritt 1, Bild 3 von 3
    • Go inside your car and press the “CAR” button on the control panel.
    • Scroll down using the control wheel to "Windshield wipers".
    • Press the center button on the control wheel to select the option.
  2. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 2, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 2, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 2, Bild 3 von 3
    • Press the center button on the control wheel to edit the service position.
    • In the drop-down menu, switch it from "off" to "on" by scrolling with the control wheel and pressing the center button.
    • The windshield wipers will now be in the up position.
  3. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 3, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 3, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 3, Bild 3 von 3
    • You should be able to lift the windshield wipers towards the windshield at 90 degrees.
    • Lift the windshield blades to about 120 degrees.
  4. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 4, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 4, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 4, Bild 3 von 3
    • In the packaging for the Michelin windshield wipers, the wipers are pre-installed with a top-lock connector.
    • Raise the pre-installed top-lock connector.
  5. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 5, Bild 1 von 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 5, Bild 2 von 2
    • Pinch the bottom of the connector to release the cover and remove the top-lock connector.
    • The Audi A4 uses a “Top Lock-Narrow” connector.
  6. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 6, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 6, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 6, Bild 3 von 3
    • Install the new "Top Lock-Narrow" connector onto the base connector.
    • Press down until it clicks into place.
  7. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 7, Bild 1 von 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 7, Bild 2 von 2
    • Install the blade into the blade arm, sliding the new wiper blades down until it clicks and is locked into place.
    • Make sure to install the 24 inches wiper blade on the driver side, and the 20 inches wiper blade on the passenger side.
  8. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 8, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 8, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 8, Bild 3 von 3
    • Install the new connector cover by pinching the base of the connector.
    • Close the connector cover on both sides of the wiper blades.
  9. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 9, Bild 1 von 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 9, Bild 2 von 2
    • Remove the yellow wiper protector on both blades.
    • Put the wiper back on the windshield
  10. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 10, Bild 1 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 10, Bild 2 von 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: Schritt 10, Bild 3 von 3
    • Set the windshield wiper service position back to "off".
Abschluss
Test the new wiper blades before you hit the road for safety.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team A-1, Morris Fall 2022 Mitglied von York University, Team A-1, Morris Fall 2022
YORK-MORRIS-F22SAG1
3 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 17
Letzte 30 Tage: 118
Insgesamt: 2,430
