Zum Hauptinhalt wechseln
How to Replace Basic Bag Lining
Was du brauchst
  1. How to Replace Basic Bag Lining, Bag Lining: Schritt 1, Bild 1 von 1
    • Assess the old bag lining you will be replacing.
    • Consider color, material, and amount of fabric needed for the new lining.
  2. How to Replace Basic Bag Lining: Schritt 2, Bild 1 von 3 How to Replace Basic Bag Lining: Schritt 2, Bild 2 von 3 How to Replace Basic Bag Lining: Schritt 2, Bild 3 von 3
    • At the seams, use your hands or sewing to carefully rip or cut out old bag lining.
  3. How to Replace Basic Bag Lining: Schritt 3, Bild 1 von 1
    • Lay out old bag lining on fabric and measure out the size of the new bag lining, adding an extra 2 cm on each side.
  4. How to Replace Basic Bag Lining: Schritt 4, Bild 1 von 2 How to Replace Basic Bag Lining: Schritt 4, Bild 2 von 2
    • Fold new fabric in half to create one closed end for the bag lining.
    • Cut out bag lining based on measurements from previous step.
  5. How to Replace Basic Bag Lining: Schritt 5, Bild 1 von 1
    • Stitch the two sides of fabric adjacent to the folded side to create a rectangle with one opening.
    • You can stitch by hand or use a sewing machine.
    • Use stitches small and tight enough to ensure new lining remains intact.
    • Finish stitching 2 cm from the end of the open side.
  6. How to Replace Basic Bag Lining: Schritt 6, Bild 1 von 1
    • Fold over extra 2 cm from the opening of the new bag lining outward to hide the raw edge of the fabric.
    • With a needle suitable for sewing through your bag material, attach the bag lining with a straight running stitch around the mouth of the bag.
    • See the article How to Work a Running Stitch from The Spruce Crafts to learn how to do a running stitch.
Ziellinie
Ijada Nguyen
133 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-1, Morris Winter 2023 Mitglied von UC Davis, Team 1-1, Morris Winter 2023
UCD-MORRIS-W23S1G1
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 99
Insgesamt: 2,597
