Zum Hauptinhalt wechseln
How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer 1997-2007
Was du brauchst
  1. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007, Battery: Schritt 1, Bild 1 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007, Battery: Schritt 1, Bild 2 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007, Battery: Schritt 1, Bild 3 von 3
    • Locate the space to put the screwdriver.
    • Put the screwdriver in this space and pry open the remote.
    • You do not need to use much force to open it.
  2. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 2, Bild 1 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 2, Bild 2 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 2, Bild 3 von 3
    • Take the half with the buttons and use your fingernails to take out the button pad.
  3. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 3, Bild 1 von 2 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 3, Bild 2 von 2
    • Clean out dirt from remote cover and button pad.
    • This helps the remote stick once you put it back together.
  4. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 4, Bild 1 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 4, Bild 2 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 4, Bild 3 von 3
    • Put the screwdriver in between the battery and the remote cover.
    • Push the screwdriver down which will make the battery pop out of the remote cover.
  5. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 5, Bild 1 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 5, Bild 2 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 5, Bild 3 von 3
    • Get your new battery and locate the positive side.
    • Put the positive side facing down towards the cover.
    • Click it into its position.
    • Take the other half of the remote and put the case back together.
  6. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 6, Bild 1 von 2 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 6, Bild 2 von 2
    • Get in your vehicle and make sure all doors are closed.
    • Put the key in the ignition.
  7. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 7, Bild 1 von 2 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 7, Bild 2 von 2
    • These are the positions the key has to be in to be on and off.
    • This position is on.
    • This position is off.
  8. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 8, Bild 1 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 8, Bild 2 von 3 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 8, Bild 3 von 3
    • Turn the car on.
    • Turn the car off.
    • Repeat this eight times.
    • Do not turn on the engine.
    • Stop on the eighth time with the key turning the car on.
  9. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 9, Bild 1 von 2 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 9, Bild 2 von 2
    • The car (not the engine) should be on for this whole step.
    • You will then hear the car lock then unlock, telling you that it is time to pair the remote with the vehicle.
    • Then press any button on the remote to pair with the car.
    • The car should then lock and unlock again to verify that your vehicle and your remote have paired.
  10. How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 10, Bild 1 von 2 How to Replace Battery and Program Keyless Entry Remote for a Mercury Mountaineer  1997-2007: Schritt 10, Bild 2 von 2
    • Turn off the car and take it out of the ignition.
    • Click all four buttons to check and see if the remote is paired.
Abschluss
Once you can lock, unlock, open the trunk, and set off the car alarm. Your keyless entry remote has been paired.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Mattel
141 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-5, Green Fall 2015 Mitglied von Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 5,140
