Zum Hauptinhalt wechseln
How to Replace Big Berkey Water Filters
Was du brauchst
  1. How to Replace Big Berkey Water Filters, Filters: Schritt 1, Bild 1 von 2 How to Replace Big Berkey Water Filters, Filters: Schritt 1, Bild 2 von 2
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: Schritt 2, Bild 1 von 2 How to Replace Big Berkey Water Filters: Schritt 2, Bild 2 von 2
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: Schritt 3, Bild 1 von 3 How to Replace Big Berkey Water Filters: Schritt 3, Bild 2 von 3 How to Replace Big Berkey Water Filters: Schritt 3, Bild 3 von 3
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: Schritt 4, Bild 1 von 2 How to Replace Big Berkey Water Filters: Schritt 4, Bild 2 von 2
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: Schritt 5, Bild 1 von 3 How to Replace Big Berkey Water Filters: Schritt 5, Bild 2 von 3 How to Replace Big Berkey Water Filters: Schritt 5, Bild 3 von 3
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: Schritt 6, Bild 1 von 2 How to Replace Big Berkey Water Filters: Schritt 6, Bild 2 von 2
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: Schritt 7, Bild 1 von 3 How to Replace Big Berkey Water Filters: Schritt 7, Bild 2 von 3 How to Replace Big Berkey Water Filters: Schritt 7, Bild 3 von 3
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: Schritt 8, Bild 1 von 3 How to Replace Big Berkey Water Filters: Schritt 8, Bild 2 von 3 How to Replace Big Berkey Water Filters: Schritt 8, Bild 3 von 3
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: Schritt 9, Bild 1 von 1
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
Abschluss
Shannon Cash
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 75
Insgesamt: 659
