Einleitung
This guide provides a simple method to replace broken deck boards on an outdoor wooden patio. Wooden boards can become damaged by impact or excessive use, water damage, age, rotting, fungus, or termites. By replacing the damaged boards, you can restore the structural integrity and appearance of your old deck, rather than replacing the entire thing.
By following all the processes, users will have fun by finishing their own DIY project that will bring more self-satisfaction.
Was du brauchst
Inspect the damage and mark any broken boards that need to be replaced using painter's tape.
Measure the replacement pieces.
Put the broken board on the new board and mark the angle it should be cut at on both sides.
Draw the line by connecting the marked points.
Mark up screws position on each new boards.
Line up the boards and mark the length where the screws should go.
Measure the position of the screws from the edge on the old boards and mark the same position on the new boards.
Pre-drill the holes at the marked spots using a 1/8th inch drill bit.
Drive screws into the pre-drilled holes.
Use a wet scrubbing sponge to clean up the lines.
