Zum Hauptinhalt wechseln
How to Replace Concealed Cabinet Hinges
Was du brauchst
    1. How to Replace Concealed Cabinet Hinges, Hinge: Schritt 1, Bild 1 von 3 How to Replace Concealed Cabinet Hinges, Hinge: Schritt 1, Bild 2 von 3 How to Replace Concealed Cabinet Hinges, Hinge: Schritt 1, Bild 3 von 3
      • Remove the screws that are attached to the cabinet door.
      • Unscrew the top and bottom hinges even if you are only replacing one hinge.
      • Remove the cabinet door from the hinge.
      • You may need to wiggle or pry the door off.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Replace Concealed Cabinet Hinges: Schritt 2, Bild 1 von 2 How to Replace Concealed Cabinet Hinges: Schritt 2, Bild 2 von 2
      • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
      • Only the hinge being replaced needs to be removed.
      Frag FixBot
    3. How to Replace Concealed Cabinet Hinges: Schritt 3, Bild 1 von 3 How to Replace Concealed Cabinet Hinges: Schritt 3, Bild 2 von 3 How to Replace Concealed Cabinet Hinges: Schritt 3, Bild 3 von 3
      • Insert the new hinge into the cabinet door's pre-cut hole.
      • Attach the hinge with the provided screws.
      • To avoid striping the screws, do not over tighten.
      Frag FixBot
    4. How to Replace Concealed Cabinet Hinges: Schritt 4, Bild 1 von 1
      • Reattach the cabinet door to the cabinet frame.
      • Do not tighten the screws all the way. You will need to align the door later.
      • You may need a friend to hold the door while you screw it back into place.
      Frag FixBot
    5. How to Replace Concealed Cabinet Hinges: Schritt 5, Bild 1 von 2 How to Replace Concealed Cabinet Hinges: Schritt 5, Bild 2 von 2
      • Lift or lower the cabinet door to align the hinges with its original location.
      • Changes in wood stain can serve as a useful alignment guide.
      • Tighten all the screws.
      Frag FixBot
    6. How to Replace Concealed Cabinet Hinges: Schritt 6, Bild 1 von 3 How to Replace Concealed Cabinet Hinges: Schritt 6, Bild 2 von 3 How to Replace Concealed Cabinet Hinges: Schritt 6, Bild 3 von 3
      • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
      • Loosen the adjustment screws, but do not remove them.
      • Slide the cabinet door to your desired position.
      • Tighten the screws.
      Frag FixBot
    7. How to Replace Concealed Cabinet Hinges: Schritt 7, Bild 1 von 1
      • Use this step if your cabinet door closes too hard or does not completely close.
      • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
      • Do not completely remove this screw.
      Frag FixBot
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
UC Davis, Team S4-G4, Cole Spring 2017 Mitglied von UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 36
Letzte 30 Tage: 215
Insgesamt: 31,472
