Einleitung
Is the trim around your door damaged or missing due to accidents, wear, or overeager pets? Use this guide to quickly replace sections of door trim.
Was du brauchst
If necessary, remove the old trim from the door.
With a hammer or pry bar, gently but firmly pry the old trim off the wall.
Start from the corner, and work along the length of the trim.
Measure the door frame.
Measure along the inside of the door frame, from floor to corner.
Make sure to record the measurement for future reference.
Measure each section of the door (the top, and both sides) in the same way.
Prepare to cut the new trim to fit the door.
Using the measurement from the previous step, mark the appropriate length on the trim to be installed.
This will mark where the trim lines up against the inside corner of the door.
Align the chop saw to make a 45 degree cut.
Consult the user's manual as needed to set up the saw correctly.
Align the trim on the saw so the mark you made is along the guide of the saw.
Again, the user's manual will provide specifics of how this is accomplished.
Align the new trim along the edge of the door. It should be lined up with the door frame.
The trim is aligned correctly when the frame is covered completely by the trim.
Use a level to ensure it is vertical.
Using trim nails, nail the trim to the wall, starting from the top.
Align each nail so it is perpendicular to the surface, and hammer it in with smooth, forceful strikes.
Nail along the inner edge as well as the outer edge.
The nails should be placed 18 to 24 inches apart along each respective edge.
A small dab of joint compound or spackling will hide the nail holes.
Place a small amount of spackling (about the size of a BB) on the tip of a finger.
Press the spackling into the nail hole.
Wipe across the top of the filled hole with a putty knife or any flat blade to remove excess spackling.
Well done! Enjoy your door's new look.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
If replacing a single section of old trim bring section of old trim to the store to match pattern and when doing stained wood have the store clerk try to match the stain.
