Zum Hauptinhalt wechseln
How to Replace Field Hockey Stick Grip Tape
Was du brauchst
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: Schritt 1, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: Schritt 1, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: Schritt 1, Bild 3 von 3
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: Schritt 2, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 2, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 2, Bild 3 von 3
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: Schritt 3, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 3, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 3, Bild 3 von 3
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: Schritt 4, Bild 1 von 2 How to Replace Field Hockey Stick Grip Tape: Schritt 4, Bild 2 von 2
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: Schritt 5, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 5, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 5, Bild 3 von 3
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: Schritt 6, Bild 1 von 2 How to Replace Field Hockey Stick Grip Tape: Schritt 6, Bild 2 von 2
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: Schritt 7, Bild 1 von 1
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: Schritt 8, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 8, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 8, Bild 3 von 3
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: Schritt 9, Bild 1 von 2 How to Replace Field Hockey Stick Grip Tape: Schritt 9, Bild 2 von 2
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: Schritt 10, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 10, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 10, Bild 3 von 3
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: Schritt 11, Bild 1 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 11, Bild 2 von 3 How to Replace Field Hockey Stick Grip Tape: Schritt 11, Bild 3 von 3
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: Schritt 12, Bild 1 von 1
    • Enjoy your new grip tape!
Ziellinie
Sophia Juan
205 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-5, Andersen Winter 2024 Mitglied von UC Davis, Team 1-5, Andersen Winter 2024
UCD-ANDERSEN-W24S1G5
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 35
Insgesamt: 531
