Zum Hauptinhalt wechseln
How to Replace Hot and Cold Water Pipes for a Washer
Was du brauchst
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: Schritt 1, Bild 1 von 1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: Schritt 2, Bild 1 von 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: Schritt 2, Bild 2 von 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: Schritt 2, Bild 3 von 3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: Schritt 3, Bild 1 von 1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: Schritt 4, Bild 1 von 1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: Schritt 5, Bild 1 von 1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: Schritt 6, Bild 1 von 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: Schritt 6, Bild 2 von 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: Schritt 6, Bild 3 von 3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: Schritt 7, Bild 1 von 2 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: Schritt 7, Bild 2 von 2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
Abschluss
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
Eine weitere Person hat diese Anleitung absolviert.
Jenish
169 Reputation
1 Anleitung geschrieben
York University, Team S1-G21, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G21, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G21
1 Mitglied
1 Kommentar zur Anleitung
Those are hoses. Pipes are in the wall
NitWit - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 28
Letzte 30 Tage: 146
Insgesamt: 10,091
