Zum Hauptinhalt wechseln
How to Replace Keys on a Keyboard
Was du brauchst
  1. How to Replace Keys on a Keyboard, Individual Keys: Schritt 1, Bild 1 von 2 How to Replace Keys on a Keyboard, Individual Keys: Schritt 1, Bild 2 von 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: Schritt 2, Bild 1 von 2 How to Replace Keys on a Keyboard: Schritt 2, Bild 2 von 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: Schritt 4, Bild 1 von 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: Schritt 5, Bild 1 von 2 How to Replace Keys on a Keyboard: Schritt 5, Bild 2 von 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Abschluss
Congratulations! You now have a keyboard with fully functional keys!
7 weitere Personen haben diese Anleitung absolviert.
Cooper
493 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 24-6, Green Winter 2015 Mitglied von Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Mitglieder
16 Anleitungen geschrieben
2 Kommentare zur Anleitung
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Antwort
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 34
Letzte 30 Tage: 185
Insgesamt: 19,930
