Einleitung
If your Magliner hand truck struggles to navigate smoothly due to worn-out wheels, this guide is here to help. Worn wheels on a hand truck can significantly impede functionality, especially in rough or greasy environments.
When a hand truck's wheels show signs of wear and tear, addressing the issue promptly is crucial to ensure smooth operation. This guide will walk you through replacing and adjusting worn Magliner hand truck wheels and restoring your equipment to optimal performance.
Was du brauchst
Straighten the bottom of the cotter pin with the pliers to slide out the cotter pin.
Remove the stainless steel washer(s) before pulling out the wheel(s) from the spindle.
Insert the new wheel into the wheel spindle.
There should be about half an inch left of the wheel spindle.
Replace the old cotter pin with a new cotter pin and slide it back into the hole at the edge of the wheel spindle.
Spread the right end of the new cotter pin(s) slightly outwards with the pliers.
