Zum Hauptinhalt wechseln
How to Replace Scott Mountain Bike Handlebars
Was du brauchst
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: Schritt 1, Bild 1 von 2 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: Schritt 1, Bild 2 von 2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: Schritt 2, Bild 1 von 1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: Schritt 3, Bild 1 von 1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: Schritt 4, Bild 1 von 1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: Schritt 5, Bild 1 von 1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: Schritt 6, Bild 1 von 1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: Schritt 7, Bild 1 von 1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: Schritt 8, Bild 1 von 1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
Abschluss
By following these steps, you will have your bike ready in no time.
Sean Slater
139 Reputation
1 Anleitung geschrieben
Cal Poly, Team 23-3, Green Winter 2015 Mitglied von Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,757
