Zum Hauptinhalt wechseln
How to Replace Sequins or Beads
Was du brauchst
  1. How to Replace Sequins or Beads, How to Replace Sequins or Beads: Schritt 1, Bild 1 von 1
    • Gather the missing sequin, a needle, and thread. Put the thread through the needle.
  2. How to Replace Sequins or Beads: Schritt 2, Bild 1 von 1
    • Double knot both ends of the thread.
  3. How to Replace Sequins or Beads: Schritt 3, Bild 1 von 3 How to Replace Sequins or Beads: Schritt 3, Bild 2 von 3 How to Replace Sequins or Beads: Schritt 3, Bild 3 von 3
    • Make an anchor stitch where the missing item needs to be.
  4. How to Replace Sequins or Beads: Schritt 4, Bild 1 von 2 How to Replace Sequins or Beads: Schritt 4, Bild 2 von 2
    • Put the missing sequin or bead through the thread.
  5. How to Replace Sequins or Beads: Schritt 5, Bild 1 von 1
    • Slide the sequin or bead down the thread to the anchor stitch.
  6. How to Replace Sequins or Beads: Schritt 6, Bild 1 von 1
    • Make a straight stitch over one side of the sequin or bead into the fabric.
  7. How to Replace Sequins or Beads: Schritt 7, Bild 1 von 1
    • Put the needle through the back of the last stitch without puncturing the fabric.
  8. How to Replace Sequins or Beads: Schritt 8, Bild 1 von 1
    • Pull the thread through enough to make a circle.
  9. How to Replace Sequins or Beads: Schritt 9, Bild 1 von 2 How to Replace Sequins or Beads: Schritt 9, Bild 2 von 2
    • Pull the thread through the circle to make a knot.
Abschluss
Repeat the procedure for all missing sequins/beads/buttons on the clothing.
Garrett Wartelle
169 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,388
