Einleitung
Use this guide to replace a broken lever in your T-fal Avante T24-B toaster.
Toasters are a staple in many households, providing a quick and easy way to make toast for breakfast, a sandwich for lunch, or a snack any time of the day. However, like any other appliance, toasters can break down over time and one of the most common problems is a broken toaster lever. A broken lever can make operating the toaster difficult and even be a safety hazard. Fortunately, replacing a broken toaster lever is a relatively simple process that can be done with just a few basic tools and some guidance. In this guide, we will walk you through the steps to replace a broken toaster lever.
Was du brauchst
Flip the toaster so that you can see its underside.
Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
Turn the toaster so that you can access the back of the toaster
Remove the 3 15 mm Torx T3 screws from the back of the toaster.
Unplug the casing so that it does not get in your way.
Unplug both wires connecting the casing to the internals of the toaster.
Pry both sides of the broken lever at the front of the toaster away and remove it.
2 Kommentare
where do you get the replacement lever ?
