Einleitung
Over time, the velcro that secures a baseball cap can collect dust and lint that renders itself useless and unable to bond. Instead of discarding the cap, you can a replace the worn out velcro by sewing a new piece of velcro onto the strap. For this fast fix, you will need to know how to sew using simple stitches.
Was du brauchst
Use a seam ripper to remove the stitching between the velcro and the hat.
Make sure to fully remove the velcro by also seam ripping the fold inside the hat.
To prepare for sewing, thread the needle with a thread color of your choice.
Pull the thread through the loop.
Make sure to leave an even amount of thread on either side of the needle.
Cut the thread.
Knot the ends of the thread together to secure.
When you come to the end, knot the thread next to the last running stitch to finish it.
Once finished, the velcro should be securely sewn on the baseball cap and ready to use.
Eine weitere Person hat diese Anleitung absolviert.
