Einleitung
In order to drive safely in rainy, snowy, and windy conditions, it's crucial to ensure that your windscreen wipers are in good condition. Worn-out wiper blades can leave your windshield dirty and compromise your visibility. This guide will help you with replacing the windscreen wiper blades for your Volkswagen Jetta 2019-2022.
Was du brauchst
Put the wipers in service position. To do that you must get into the vehicle.
Then push the ignition button ON and OFF.
Push the wiper stock down once which will lift your wiper arms.
After you are done with your first step your wiper blades position should be up as shown in the image.
Once they are in the service position lift the wiper blades to about 120 degree.
Remove the old wiper blade by pressing the little square button on the wiper mounting arm.
Keep pressing the button while lifting the wiper blade in the direction of the wiper arm and pull the wiper blade away from the arm.
Now take the new wiper blade and sliding directly into the wiper arm mount. You will hear a click once the new blade has been mounted properly.
Make sure the new wiper blades latches perfectly with the mount.
Remove the cloth from the windshield and place your wipers gently onto the windscreen.
You can follow the same steps for the other wiper arm. Also make sure to check the wipers before hitting the road.
