Zum Hauptinhalt wechseln
How to Replace a BHG Digital Clock Screen
Was du brauchst
  1. How to Replace a BHG Digital Clock Screen, Screen of a Digital Clock: Schritt 1, Bild 1 von 2 How to Replace a BHG Digital Clock Screen, Screen of a Digital Clock: Schritt 1, Bild 2 von 2
    • Remove the batteries from the back of the clock.
  2. How to Replace a BHG Digital Clock Screen: Schritt 2, Bild 1 von 3 How to Replace a BHG Digital Clock Screen: Schritt 2, Bild 2 von 3 How to Replace a BHG Digital Clock Screen: Schritt 2, Bild 3 von 3
    • Unscrew the eight 10 mm Philips #1 screws in the back frame.
    • Remove the back frame.
    • Take out the fourteen Phillips #0 8 mm screws on the circuit board and the plastic bars that hold the screens.
  3. How to Replace a BHG Digital Clock Screen: Schritt 3, Bild 1 von 3 How to Replace a BHG Digital Clock Screen: Schritt 3, Bild 2 von 3 How to Replace a BHG Digital Clock Screen: Schritt 3, Bild 3 von 3
    • Carefully remove both the top and middle circuit boards together away from the screen.
  4. How to Replace a BHG Digital Clock Screen: Schritt 4, Bild 1 von 3 How to Replace a BHG Digital Clock Screen: Schritt 4, Bild 2 von 3 How to Replace a BHG Digital Clock Screen: Schritt 4, Bild 3 von 3
    • Remove display screen at the top and the bottom.
  5. How to Replace a BHG Digital Clock Screen: Schritt 5, Bild 1 von 2 How to Replace a BHG Digital Clock Screen: Schritt 5, Bild 2 von 2
    • Place the new display screens on the clock.
  6. How to Replace a BHG Digital Clock Screen: Schritt 6, Bild 1 von 3 How to Replace a BHG Digital Clock Screen: Schritt 6, Bild 2 von 3 How to Replace a BHG Digital Clock Screen: Schritt 6, Bild 3 von 3
    • Align the circuit board to the pink rubbery connectors.
    • Screw everything back together.
Abschluss
Insert batteries to see if the new display works correctly.
Joselyn Vazquez
133 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 2-8, Bennett Fall 2023 Mitglied von Sam Houston State, Team 2-8, Bennett Fall 2023
SHSU-BENNETT-F23S2G8
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 225
