Zum Hauptinhalt wechseln
How to Replace a Bicycle Bell Disc
Was du brauchst
  1. How to Replace a Bicycle Bell Disc, Disc Bell: Schritt 1, Bild 1 von 2 How to Replace a Bicycle Bell Disc, Disc Bell: Schritt 1, Bild 2 von 2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: Schritt 2, Bild 1 von 2 How to Replace a Bicycle Bell Disc: Schritt 2, Bild 2 von 2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: Schritt 3, Bild 1 von 2 How to Replace a Bicycle Bell Disc: Schritt 3, Bild 2 von 2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: Schritt 4, Bild 1 von 1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: Schritt 5, Bild 1 von 2 How to Replace a Bicycle Bell Disc: Schritt 5, Bild 2 von 2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: Schritt 6, Bild 1 von 2 How to Replace a Bicycle Bell Disc: Schritt 6, Bild 2 von 2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Abschluss
Your bell should now be ringing like new!
Susan
133 Reputation
1 Anleitung geschrieben
York University, Team N-10, O'Regan Winter 2022 Mitglied von York University, Team N-10, O'Regan Winter 2022
YORK-O'REGAN-W22SNG10
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 32
Letzte 30 Tage: 97
Insgesamt: 1,289
