Einleitung
Has the guide pulley in your bike's derailleur been dislodged, broken, or lost? Here's a guide on how to replace it.
Was du brauchst
Set your bike upside down by letting it stand on its handlebars and seat.
If the pulley is still in place, unscrew it from the arm with the allen wrench.
Using the towel with the alcohol or degreaser, clean the pulley and check for cracks or broken teeth.
If any extensive damage is present, discard the pulley.
The replacement pulley should come with a bearing. Remove the bearing.
Grease the pulley and bearing thoroughly.
Place the teeth of the pulley against the chain, then push it with the chain into the derailleur arm.
Grease the screw that holds the pulley in place.
Screw the pulley back into the derailleur with the allen wrench.
While temporarily lifting the chain off the pulley, check to see if the pulley rotates freely.
To remove your pulley, see Step 2.
