Zum Hauptinhalt wechseln
How to Replace a Bicycle Guide Pulley
Was du brauchst
  1. How to Replace a Bicycle Guide Pulley, Bicycle Guide Pulley: Schritt 1, Bild 1 von 1
    • Set your bike upside down by letting it stand on its handlebars and seat.
  2. How to Replace a Bicycle Guide Pulley: Schritt 2, Bild 1 von 3 How to Replace a Bicycle Guide Pulley: Schritt 2, Bild 2 von 3 How to Replace a Bicycle Guide Pulley: Schritt 2, Bild 3 von 3
    • If the pulley is still in place, unscrew it from the arm with the allen wrench.
    • Using the towel with the alcohol or degreaser, clean the pulley and check for cracks or broken teeth.
    • If any extensive damage is present, discard the pulley.
    • Be sure to clean and check the pulley's condition if it has fallen out of the arm.
  3. How to Replace a Bicycle Guide Pulley: Schritt 3, Bild 1 von 2 How to Replace a Bicycle Guide Pulley: Schritt 3, Bild 2 von 2
    • The replacement pulley should come with a bearing. Remove the bearing.
    • Grease the pulley and bearing thoroughly.
  4. How to Replace a Bicycle Guide Pulley: Schritt 4, Bild 1 von 2 How to Replace a Bicycle Guide Pulley: Schritt 4, Bild 2 von 2
    • Push the bearing back into the pulley.
  5. How to Replace a Bicycle Guide Pulley: Schritt 5, Bild 1 von 3 How to Replace a Bicycle Guide Pulley: Schritt 5, Bild 2 von 3 How to Replace a Bicycle Guide Pulley: Schritt 5, Bild 3 von 3
    • Place the teeth of the pulley against the chain, then push it with the chain into the derailleur arm.
  6. How to Replace a Bicycle Guide Pulley: Schritt 6, Bild 1 von 2 How to Replace a Bicycle Guide Pulley: Schritt 6, Bild 2 von 2
    • Grease the screw that holds the pulley in place.
    • Screw the pulley back into the derailleur with the allen wrench.
  7. How to Replace a Bicycle Guide Pulley: Schritt 7, Bild 1 von 1
    • While temporarily lifting the chain off the pulley, check to see if the pulley rotates freely.
  8. How to Replace a Bicycle Guide Pulley: Schritt 8, Bild 1 von 1
    • Push on the pedals to see if the derailleur is back in working order.
Abschluss
To remove your pulley, see Step 2.
Kayla Bru
128 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-6, Green Fall 2015 Mitglied von Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,448
