Zum Hauptinhalt wechseln
How to Replace a Bike Chain With a Master Link
Was du brauchst
  1. How to Replace a Bike Chain With a Master Link, Bicycle Chain: Schritt 1, Bild 1 von 1
    • Rotate the chain until the master link is in an accessible place.
    • The master link will be visually different from the rest of the links. It will have a gap next to one of the pins on each side, and it may be a different color.
  2. How to Replace a Bike Chain With a Master Link: Schritt 2, Bild 1 von 3 How to Replace a Bike Chain With a Master Link: Schritt 2, Bild 2 von 3 How to Replace a Bike Chain With a Master Link: Schritt 2, Bild 3 von 3
    • Using one hand, pull the rear derailleur forward to create slack in the chain.
    • Using your other hand, lift the chain off of the front gears, setting it down on the "inside," between the gears and the bicycle's frame.
  3. How to Replace a Bike Chain With a Master Link: Schritt 3, Bild 1 von 3 How to Replace a Bike Chain With a Master Link: Schritt 3, Bild 2 von 3 How to Replace a Bike Chain With a Master Link: Schritt 3, Bild 3 von 3
    • Disengage the master link by pushing the links on either side of it together.
    • If this is too difficult by hand, use a pair of needle nose pliers to squeeze pins of the master link together.
    • After the master link is disengaged, pull the chain apart by separating the two halves of the master link.
    • Pull the two halves of the master link out of each end of the chain, and set them aside.
  4. How to Replace a Bike Chain With a Master Link: Schritt 4, Bild 1 von 1
    • Check which rear gear the chain is currently on; you'll need to remember this for reassembly.
    • Remove the chain from the bike by pulling it through the rear derailleur.
  5. How to Replace a Bike Chain With a Master Link: Schritt 5, Bild 1 von 1
    • Thread the new chain through the front derailleur.
    • The front derailleur is the black metal loop above the gear.
  6. How to Replace a Bike Chain With a Master Link: Schritt 6, Bild 1 von 3 How to Replace a Bike Chain With a Master Link: Schritt 6, Bild 2 von 3 How to Replace a Bike Chain With a Master Link: Schritt 6, Bild 3 von 3
    • Set the chain onto the same rear gear you removed the previous chain from earlier.
    • Thread the chain down and around the first derailleur gear...
    • ...then between the two derailleur gears...
    • ...then around the other derailleur gear.
    • Be sure to thread the chain through the chain guard, rather than over it.
  7. How to Replace a Bike Chain With a Master Link: Schritt 7, Bild 1 von 2 How to Replace a Bike Chain With a Master Link: Schritt 7, Bild 2 von 2
    • Slide the pin of one of the master link halves through the end of one end of the chain.
    • Attach the other half to the other end in the opposite direction. ("From the front" on one end, and "from the back" on the other end.)
  8. How to Replace a Bike Chain With a Master Link: Schritt 8, Bild 1 von 2 How to Replace a Bike Chain With a Master Link: Schritt 8, Bild 2 von 2
    • Slot the two halves of the master link together. One half's pin should go in the other's hole, and vice versa.
  9. How to Replace a Bike Chain With a Master Link: Schritt 9, Bild 1 von 3 How to Replace a Bike Chain With a Master Link: Schritt 9, Bild 2 von 3 How to Replace a Bike Chain With a Master Link: Schritt 9, Bild 3 von 3
    • Hold the chain on either side of the master link, and pull them apart. The master link will snap in place, with each pin now in its "outer" hole rather than its "inner" hole
  10. How to Replace a Bike Chain With a Master Link: Schritt 10, Bild 1 von 3 How to Replace a Bike Chain With a Master Link: Schritt 10, Bild 2 von 3 How to Replace a Bike Chain With a Master Link: Schritt 10, Bild 3 von 3
    • Pull the rear derailleur forward to create slack in the chain, just like in Step 1.
    • Set the chain onto the front gear.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 72
Insgesamt: 1,820
