Einleitung
This guide will walk you through the process of replacing a broken lamp cord and rotary switch with a new lamp cord and toggle switch. Using a lamp with a broken or faulty cord or switch is both dangerous and a fire hazard, and rotary switches are often difficult to use and easy to break.
Steps 14 and 18 require you to strip a wire. If you don't know how to do this, visit this guide on wire stripping to learn more.
Before you begin, be sure to unplug your lamp and move your lamp shade to an out-of-the-way location.
Was du brauchst
Pinch the lamp shade hanger inwards.
Move one side of the lamp shade hanger out from under the clamp.
Take off the lamp shade hanger.
Use the 1/4" flathead screwdriver to unscrew the socket screw to loosen the socket.
Take the socket out of the socket shell.
Use a Phillips #2 screwdriver to partially unscrew the screws holding the copper wire to the socket so that you can disconnect the copper wire.
Take the old wire out of the socket.
Thread the cord through the lamp shade hanger clamp.
Attach the lamp shade hanger clamp back onto the lamp body.
Thread the cord through the socket cap.
Attach the socket cap back onto the lamp body.
Screw the socket screw back into the socket cap with the 1/4" flathead screwdriver.
Tie an Underwriter's Loop with the following steps:
Loop the left side of the cord around and hold it behind the right side.
Loop the right side of the cord around the end of the left side.
Thread the end of the right side through the left loop.
Gently pull on both ends of the cord to tighten the knot.
Using your wire trimmers or multi-tool, strip away the cord casing on each side to expose the ends of the copper wire.
Gently twist the exposed copper wire on each side.
Bend the copper wire to create a hook shape.
Hook the smooth side of your cord over the brass screw.
Gently tighten the screw with the Phillips #2 screwdriver until you can't pull the copper wire out.
Hook the ribbed side of your cord over the silver screw and tighten the screw with the Phillips #2 screwdriver.
Once you have tightened the screws, loosen the underwriter's knot slightly, so that there is plenty of slack in the knot.
Place the socket shell back onto the socket.
Push the socket shell and cap back together.
Mark where you want your toggle switch to go.
Using the wire trimmers, cut the cord on the mark.
Pull the ends of the cord apart.
Using your wire trimmers or multi-tool, strip the cord casing away from the copper wire on both sides of the cord.
Gently twist both ends of the copper wire.
Unscrew the two screws on the back of the toggle switch with the Phillips #2 screwdriver to open up the switch.
Loosen, but don't remove, the four screws on the copper plates with the Phillips #2 screwdriver.
To place the wire, follow these steps:
Thread one end of the copper wire through the hole underneath one screw.
Tighten the screw with the Phillips #2 screwdriver so that it clamps the copper wire to the copper plate.
Repeat the above steps for each end of the cord.
Hold a wire clip over one end of your cord.
Screw the clip back onto the switch with the Phillips #2 screwdriver.
Repeat for the other side.
You should now have a fixed, functional lamp with a new cord and toggle switch.
