Zum Hauptinhalt wechseln
How to Replace a Coffee Tabletop Glass
Was du brauchst
  1. How to Replace a Coffee Tabletop Glass, Coffee Table Glass: Schritt 1, Bild 1 von 2 How to Replace a Coffee Tabletop Glass, Coffee Table Glass: Schritt 1, Bild 2 von 2
    • Flip the coffee table base upside down on an empty area.
  2. How to Replace a Coffee Tabletop Glass: Schritt 2, Bild 1 von 1
    • Use a cleaning spray to clean the surface of the glass table.
    • Use gloves while cleaning the table. The glass cleaner spray may contain toxic chemicals.
  3. How to Replace a Coffee Tabletop Glass: Schritt 3, Bild 1 von 2 How to Replace a Coffee Tabletop Glass: Schritt 3, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove one 1/4 in.-20 x 1-1/2 in. socket cap screw from the side of the glass.
    • Repeat the process for the other 1/4 in.-20 x 1-1/2 in. socket cap screw.
    • The appearance of this screw may differ from table to table, but the procedure remains the same. Use the appropriate screwdriver to open the screws.
  4. How to Replace a Coffee Tabletop Glass: Schritt 4, Bild 1 von 2 How to Replace a Coffee Tabletop Glass: Schritt 4, Bild 2 von 2
    • Remove the coffee table legs piece by piece.
  5. How to Replace a Coffee Tabletop Glass: Schritt 5, Bild 1 von 1
    • Remove the glass.
    • Remember that glass can be shattered or partially damaged. Use gloves to avoid possible cuts.
  6. How to Replace a Coffee Tabletop Glass: Schritt 6, Bild 1 von 1
    • Replace the broken/ damaged glass with the new one.
Abschluss
Jasrin Kaur
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G31, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G31, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G31
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 83
Insgesamt: 2,415
