Zum Hauptinhalt wechseln
How to Replace a Curtain Rod
Was du brauchst
  1. How to Replace a Curtain Rod, Curtain Rod: Schritt 1, Bild 1 von 2 How to Replace a Curtain Rod, Curtain Rod: Schritt 1, Bild 2 von 2
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: Schritt 2, Bild 1 von 3 How to Replace a Curtain Rod: Schritt 2, Bild 2 von 3 How to Replace a Curtain Rod: Schritt 2, Bild 3 von 3
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: Schritt 3, Bild 1 von 2 How to Replace a Curtain Rod: Schritt 3, Bild 2 von 2
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: Schritt 4, Bild 1 von 2 How to Replace a Curtain Rod: Schritt 4, Bild 2 von 2
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: Schritt 5, Bild 1 von 1
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: Schritt 6, Bild 1 von 2 How to Replace a Curtain Rod: Schritt 6, Bild 2 von 2
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: Schritt 7, Bild 1 von 2 How to Replace a Curtain Rod: Schritt 7, Bild 2 von 2
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: Schritt 8, Bild 1 von 2 How to Replace a Curtain Rod: Schritt 8, Bild 2 von 2
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
Ziellinie
Andrew Pfeiffer
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 1,199
