Zum Hauptinhalt wechseln
How to Replace a Felt Chair Footing
Was du brauchst
    1. How to Replace a Felt Chair Footing, Felt Footing: Schritt 1, Bild 1 von 1
      • Turn furniture piece upside down so that the leg bottoms are accessible.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Replace a Felt Chair Footing: Schritt 2, Bild 1 von 3 How to Replace a Felt Chair Footing: Schritt 2, Bild 2 von 3 How to Replace a Felt Chair Footing: Schritt 2, Bild 3 von 3
      • Using an Exact-o knife or boxcutting blade, carefully cut away the worn out felt footing.
      Frag FixBot
    3. How to Replace a Felt Chair Footing: Schritt 3, Bild 1 von 1
      • Cut away any remaining material or residue so that the chair foot is as clear as possible.
      • Depending on the strength of the adhesive that secured the old footing, some of the residue left behind could be tough to remove. In this case, it may be best to keep some rubbing alcohol handy as a solvent to assist in the removal of this residue.
      Frag FixBot
    4. How to Replace a Felt Chair Footing: Schritt 4, Bild 1 von 2 How to Replace a Felt Chair Footing: Schritt 4, Bild 2 von 2
      • Use pre-cut felt footing replacements to replace the old footing. Press felt footing into center of chair foot firmly.
      Frag FixBot
    5. How to Replace a Felt Chair Footing: Schritt 5, Bild 1 von 1
      • Repeat steps 2 and 3 for the remaining three footings.
      Frag FixBot
Abschluss
Now you’re done! With all four footings replaced, you can replace your furniture.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 73
Insgesamt: 3,023
